Can anyone provide drivers for Chuwi cwi 535? I reinstalled Win 10 and can`t find the fitting drivers set. Thanks in advance!
Please tell me the model and serial number of the device.
Hallo,
I have The same problem an need the link to the driver package or the link to the complete Image of UBook Pro (N4100)
SN: GLK UBook PQ256G20033721
Amazing, everything works fine now, thanks so much!
Can anyone give me link to the BIOS for CWI535?!
i need, after fresh Windows install, the drivers for
can anyone give me the Link for Download
Thank you
These drivers are also valid for Ubook X??
hi,
I have some problem with my ubook XQ256G21012780 TYPE CWI535 after win11 installation.
I want to reinstall win 10 but the SSD is dead.
Have you an image, drivers or anythink else for restore my chuwi?
Can I use this for ubook x
how do i install the audio drivers [ap123]
Tell me your model and serial number and i will send them, because i am not sure is the same file
@Blaze_D
Try this one
UBook X CWI535 XQ256G21051270. Please can you provide me driver package. I like to reinstall new OS. First I like to try win11 and later maybe also a linux distribution if it is not fast enough. Could you help me with the driver and maybe a recommendation of a linux distro. Thank you so much.
