Chuwi does not sell spare parts for Hipad
The screen of the chuwi hipad has broken and it seems to me that I am out of tablet. Chuwi does not sell the screen and in aliexpress they sell the lcd and the touch separately and from what a technician tells me they cannot be pasted.
Does anyone have a solution or do I drop the tablet directly?
Find another workshop, the display and touchscreen can be easily separated and glued together If you have the right equipment.
You can also order the display and touchscreen and simply do not glue them together.
I have been told in an aliexpress store that it can be glued with B7000 glue. But I find it very curious. At first only the touch screen broke and I asked for it in a store but the technician could not glue it to the lcd screen because the glue he used expanded.
Heat is your friend for removal, use Apple compound to remount.
Hello I got problem with chuwi hipad x. I forgot the password that I set for it. Therefore I cannot open the tab. What can I do?
The only way I know off, is calling the android interface on booting and resetting it. This would erase everything on it. I am sure there is an other way , either with usb c or with other fonction. If I find out, I will let you know.
Thank sir. Looking forward with your post soon, thank you
