The header and the navigation bar doesn’t stick to the top when scrolling down. It is the same on mobile view which makes it hard to go through the threads.
It keeps dragging down as we scroll
I’m using the incognito mode of Google Chrome to see if the layout breaks or not.
I don’t have any addons and the mode does not let any of them work.
So, the result was the same as what Spikerguy showed.
It might be a compatibility problem.
I am just doing my part of informing in the forum about this glitch as a responsible forum user
It is upto the chuwi admin’s whether they want to fix it or not.
I was able to duplicate the ‘spikerguy’ issue … very odd issue and occurs with Firefox (64bit) for Linux Mint v.84.0.1 and Firefox v.84.0.1 (64bit) for Windows 10 (OS build 19042.685 ver. 20H2) and Chrome v.87.0.4280.88 (64bit) for Win10 (same version) and Edge v.87.0.664.66 (64 bit) for Win10 (same version). Windows browsers tested on Chuwi Larkbox w/ Intel UHD Graphics 600 - driver version 27.20.100.9079. I’ve noticed the issue for a while now myself, but never bothered to worry about it … very odd that it seems to perform normally on the phone app but not on some PC applications … perhaps a ‘fine-tuning’ issue within the browser or video driver settings ?
I am browsing the Chuwi forum with google Chrome both through PC and mobile and it does not happen to me. The forum looks correctly.
Try deleting cookies
I had a similar problem right after registering. To solve it, go to settings in your profile, change the interface theme to any other, then you can return the default theme and the problem will disappear. Just change the interface theme and everything will be fine
