Fix fcked UI on mobile
I am using this app on mobile and DDG on Adroid and UI is all ver the place so please fix that. I kbow your just using a template for your forums and I bet there is new version so just update your forum engine please.
Can you please send me a screen capture? because with my phone i see it ok no problem. Maybe i can contact the forum hosting service to see what is happening
This is what the app lookes on my phone with elements all over the place and no option to scale out (lots of compresion to get under 4mb):
I will write to Discord , that is the provider of the forum to see if they can help. If anyone else have the same issue i would appreciate you guys write here
Thanks in advance!
Yeah, I hear you. The mobile UI can be a mess sometimes. It might be worth reaching out to their support or checking for updates
