How to Install Missing Drivers for Chuwi Freebook i3-1215U
Download and Extract Drivers
Download the zip file from the link below. Ensure you have the folder Chuwi Freebook i3-1215U Drivers extracted and accessible on your PC.
https://www.mediafire.com/file/s17pbbo4tu4i5uu/Chuwi_Freebook_i3-1215U_Drivers.zip/file
- Open Device Manager
- Press
Win + Xand select Device Manager from the menu. - Alternatively, search for “Device Manager” in the Windows search bar and open it.
- Locate the Device with Missing Driver
- Look for devices with a yellow triangle (
) or listed under Other devices indicating missing drivers. - Open Driver Update Window
- Right-click the device with the missing driver and select Update driver.
- Choose Manual Installation
- In the Update Driver window, select Browse my computer for drivers.
- Point to the Drivers Folder
- Click Browse, navigate to the root folder
Chuwi Freebook i3-1215U Drivers, and ensure the checkbox Include subfolders is selected. - Click OK and then Next.
- Install the Driver
- Windows will search through the folder and subfolders, locate the correct driver, and install it.
- If prompted, confirm any on-screen instructions.
- Repeat for Each Device
- Repeat steps 3–7 for each device with missing drivers in Device Manager.
- Restart Your Computer
- After installing all the drivers, restart your computer to ensure everything is applied properly.
