Hi everyone,
I have a Herobook Pro JHeroBP256G201010862, the motherboard is X133GRX170-G60E.
When i turn on the laptop there is a bios password request, someone can help me? I need or a bios dump or a bios unlocked
I attached some photo
Thanks so much
Buenas amigo tengo ese mismo problema, alguien tendrá respuesta de esto. Gracias
envia número de serie
i can romove the passoword bios with that ?
Hi Maher,
If you have a dump of your BIOS, you can send it to me at a.biancoxx88@hotmail.it I can remove the password for you, but I need your BIOS dump first. Once I have it, I’ll send the modified version back to you. It only takes about 5 minutes on business days.
Hi, this link don´t work. is empty.
Thank, i don´t have a dump of the BIOS.
