Hi , i had to reinstall windows 11 home on my hi10 max and the touch screen isnt working , i tried to search by serial on suport but it says “Database Working Un-normal now, Please contact local retails and distributor for Service”. Can you get me the drivers or help in some way? The serial number is ZHiMaxHZ1H241003232
Not all the driver from this thread’s zip file are compatible with N150 model.
Do you have also a bundle for the latest model with N150 chip (Hi10 Max N150) ?
Many thanks!
Need the serial number
send serial number
Hello, my chuwi’s touch doesn’t work. I need help with my serial number
ZHiMaxH21H240704195
Hello i just got HI10 Max and i would like to have drivers in my backup folder if something happens down the line.
SN
btw is this safe methode to ask for a driver by giving devices SN publicly?
Love HI10 for now
Tnx didnt know it works like that
YOu can send the SN no problem in public. No one can do anything with them
Hi, i have Win11 new installed but i need the drivers can you send me a download link?
My Serial: ZHiMaxHZ1H250500440, Many thanks!
Many thanks!
Got this. My problem same on my Chuwi Hi10 Max N100
Serial: ZHiMaxH21H240602570
Hi, i Need a driver for hi10 max.
My serial Number Is ZHiMaxHZ1H250500968
my serial number is ZHiMaxHZ1H241001578.
can i use windows image and drivers that posted aobve?
You can download the drivers from the Chuwi website, support, downloads
As far as I know, each series has different drivers.
