Chuwi Hi10 Pro Low Volume
I just bought a Chuwi Hi10 Pro and the speaker volume is very low. I have raised the volume setting all the way up to 100 percent but it is still low. I have made sure the Windows 10 operating system and audio drivers are all up to date. Has anyone run into this problem before.
Try to disable “speaker equalizer” in sound control panel->speakers->properties->system effects.
Good morning Max,
I tried the disable equalizer chance but it did not have any effect. The volume is still low.
Brian
I also have a hi10 pro, and it sounds very loud even on stock drivers.
Do you have the same problem in android? This could be a hardware problem.
Did you ever find a fix for this problem? I have the same problem and am not computer savy
No, I still have the same issue. Let me know if you find a fix.
Thanks,
Brian
Brian Parks
(248) 910-4504
