Chuwi Hi10 X1 Ubuntu screen rotate problem
Hi everybody. Be gentle with me it’s my 1st message on Chuwi’s Forum.
I bought the latest Chuwi Hi10 X1 with the N150 CPU to be my compagnon while I’m traveling. It’s a nice piece of hardware.
Here is my problem :
I successfully installed Linux Mint 22 (based on Ubuntu 24.04 LTS).
To make my graphic card to work I had to upgrade the kernel to version 6.11 and now, everything work : WiFi, BT, Touch screen, Screen rotation,…
Well almost everything… since the screen rotation is by default always rotated 270° (when in landscape it display in portrait) and when I rotate the screen, the display rotate too but still by 270°.
Very inconfortable situation isn’t it?
So, I’m asking if someone had / has the same behavior and how to correct this.
Any help or support is welcome.
Well, after looking for a way to correct this behavior, I managed to fix the 90° right rotation problem by finding a video on YouTube that explains exactly what to do:
There is indeed a file that allows to configure the rotation offsets of tablet PC LCD screens.
After finding the right sensor specifications, I opened as superuser the file
Code: Select all
/lib/udev/hwdb/60-sensor.hwdb
and I added the following entries at the end of the file for my tablet:
Code: Select all
# Chuwi Hi10 X1
sensor:modalias:acpi:NSA2513*:dmi:*:svnCHUWIInnovationAndTechnology*:pnHi10X1:*
ACCEL_MOUNT_MATRIX=0, 1, 0; -1, 0, 0; 0, 0, 1
Followed by updating the table:
Code: Select all
$ sudo udevadm hwdb --update
and a reboot to take effect:
Code: Select all
$ reboot
After the reboot, the screen is now horizontal when the tablet is in landscape mode and rotates correctly when I turn it. The mouse and touch screen also work correctly.
I hope this helps others who are having similar problems.
thank you for this, im sure many users will echek it
You’re welcome.
