I have a HeroBook Plus that I mainly use for writing and browsing, and it has been fine for that. Lately I’ve been thinking about using it for light video editing — mostly short clips for family, nothing fancy, just trimming and adding a few transitions. I know the hardware is modest and that’s my main worry: whether the CPU and integrated graphics will choke once clips get longer or I add a couple of layers, and whether the fan noise becomes annoying.
I don’t want to spend money on new gear if the laptop can handle simple projects, but I also don’t want to start something and hit a wall partway through. If anyone here uses a CHUWI laptop for basic editing, I’d like to hear what kind of footage and software you work with, and where you noticed slowdowns. What settings or workflow tweaks helped most, and is there a point where I should just stop trying?
Update after poking around a bit - Tech News had some general discussion on modest laptops and editing, though nothing specific to the HeroBook Plus. Still unsure whether longer clips would choke it, but I’m leaning toward testing a short project before buying anything.
