This will not work, unfortunately. LarkBox doesn’t support PD or QC, so it can only be powered with a DC adapter rated at 12V. They do use Type-C port, mind you, but it’s kind of a fake Type-C, no USB features in that port at all.
Actually, Chuwi Hi10x also suffer the same problem (and consider it is a tablet!). If you check out Hi10x forum, you will found out you can solve this by using a 12V PD Trigger cable.
These are the cables I used:
I have tried my setup on Hi10x and Larkbox using a PD charger and they both work. Have not tried on a PD battery yet.
I just got a few of those cables from eBay and they appear to be working fine with my LarkBox. I had a few 12v adapters for HDD caddies and those adapters worked using these cables.
Is this also the case in the Hi10 Air tablet PC? It does have a USB-C port, but does it require a non-standard level of power? I once tried a USB-C “dongle dock” that supposedly would transfer power to the host but failed to do so. Maybe I actually toasted it by connecting the Chuwi power brick to its input?
I finally managed to run my Larkbox via powerbank, here is how:
you need to have a Power delivery Power Bank
you need to have a PD trigger gircuit capable of requesting the required 12V from the power bank.
I have used a ZY12PDN circuit (you can find from Amzn, Ebay etc)
Where did you get the black USBA to USBC cable in the photo? (attached to the Larkbox). I have the other 2 items, but not that one… don’t even know what to search for.
Hello
I have no idea ho long will it last: after 3 hours the Power Bank was still at 75%
it is rated at 26800 mAh but I think it really depends on how much you load the CPU
Thank you for your insight. I’m about to buy larkbox and use powerbank as you did. Is powerbank with PD rated USB-C PD 12V/1.5A ok for running larkbox with parameter Voltage : 12V/2A?
Would that 1.5 A be enough or it has to be strictly 2A? I can find power banks with PD rated as 12V/3.A …would that be better option? What parameters do your power bank has?
