Hello, I have a Chuwi MjBook 256G210106047, the problem is that even after installing the version of Windows 10 and updating it correctly, it still works poorly, since the processor is used at 100% without running any application or program, the same when playing videos, IN THEORY I SUPPOSE THE PROBLEMS COME FROM THE DRIVERS, don’t you have the links to the corresponding drivers for this model? Or some specific Chuwi update tool. Something that can help me install the correct and recommended drivers for the model. THANK YOU
You can download the drivers from the Chuwi website, support
The problem is that my device is not listed on Chuwi’s list of devices. I suppose it’s because it’s an old model or something.
You can write to support from the Chuwi website, Contact aftersales support
@ChuwiESnotactive plis
La sugerencia es crear un ticket de soporte
Pues no encuentro la opción para crear un ticket al soporte.
Este es el foro tienes que entrar en la web de Chuwi
Bruzan ya vengo yo usualmente y envio los links de los archivos para no colapsar más a soporte,
El ordenador es super super antiguo
Quizás @manonegra222 pueda ayudar,
