Chuwi Ubook 11.6 SD card slot not working
Hi, I had tried serveral Micro SD card, from 2GB to 128GB. BUt none can be detected by the the Card slot on the Ubook.
But if I use a convert to plug the SD card to USB port, it can detect.
the same here, bro, its really a problem…
do you know how to work??
My issue hadn’t solved yet.
Also the same on my HeroBook Pro!!
Also I found in Bios the SD is dissable but also in enable doesnt work!
Please HELP
Thanks from Austria
Peter
