Chuwi Unitech 27" 2K Ryzen 5 6600H (3.3) 32Gb SSD1Tb 660M firmware
Do you have new firmware for Chuwi Unitech 27" 2K Ryzen 5 6600H (3.3) 32Gb SSD1Tb 660M
What problem are you having with the device ?
When the power is off, all USB ports remain powered.
I want to disable usb power.
I can’t find this feature in my version of the BIOS.
What is the problem with having USB power enabled ?
If you don’t have the option to disable USB, you need to enable the advanced BIOS settings.
You can find tutorials on Google.
There is no such options in Advanced Settings.
As far as I know, the computer only has USB power when it is in standby mode.
When the computer is turned off, it does not have USB power.
No. My monoblok have power.
I connected to USB a DVD drive and active speakers and they all flicker at night.
Is it only connected to the computer or does it have an external power supply ?
I think in the BIOS you have to press F5 and restart, entering the BIOS.
Yes, to USB only
Why not turn off your computer at night ?
Computer is turned off. But all USB outputs have power.
I want to disable this .
I don’t have the devices you have.
With the mini PC turned off, I tried connecting the phone and it didn’t show any signs of charging.
You can ask customer service: service@chuwi.com
I tried all of key combinations, but they don’t work.
You search on Google and look for a tutorial on YouTube.
I think it was Alt+F5.
Yes, I confirm this problem. The USB ports work (supply power) after turning off the all-in-one, it doesn’t turn off in bios!
Let’s stop thinking about the BIOS, for a simple solution:
connect the devices to a power strip with a switch.
That’s exactly what I did, but it’s a “crutch”
Please, explain step by step how you activated BIOS advansed mode.
Please explain step by step how to turn off USB - so that others can understand when the BIOS is incomplete. Algorithm (from the author). Thank you )
Key combination Alt+F5 working inside Bios. After pressing some new advansed items will appear.
There are options about USB power, but its only disable usb ports during boot.
Note!!! After this, it is impossible to enter into the BIOS from a USB keyboard.
