Hibernation: how to set USB port power off
Hallo,
USB port are powered in hibernation state (I see status led of my USB hub on and Mouse light on !). How can I turn off power supply ? BIOS settings ???
Disable USB Ports in Hibernation Mode
Method 1: Enable / Disable Power Saving on USB Ports
  1. Press the Windows key + R to open the Run box. Type devmgmt.msc and press Enter.
  2. When the Device manager window opens, expand the Universal Serial Bus controllers branch, then right-click the USB Root Hub device and select Properties
    usb-root-hub
  3. Click the Power Management tab. If you want USB ports to keep supplying power in sleep mode, just uncheck “ Allow the computer to turn off this device to save power “. Or check it to let Windows turn off USB ports to save power.
    turn-off-this-device-to-save-power
  4. Repeat steps 3 and 4 for all of the USB Root Hubs on the computer.
    Note: Windows will clear the check box “ Allow the computer to turn off this device to save power ” when the device is unplugged from the USB port or the PC is restarted. To keep this from happening, use the method below to disable USB selective suspend setting.
    Method 2: Enable / Disable USB Selective Suspend Setting
  5. Press the Windows key + R to open the Run box. Type powercfg.cpl and press Enter.
  6. When the Power Options window opens, click the Change plan settings link to the right of your current power plan.
    change-plan-settings
  7. Click the “ Change advanced power settings ” link.
    change-advanced-power-settings
  8. Expand the “ USB settings ” and then expand “ USB Selective suspend setting “. Set it to Disabled if you want to stop Windows from powering down any connected USB devices.
    usb-selective-suspend
    1. Click Apply to save your changes.
