CoreBook Plus CWI626 Drivers
214-230202
I buy it Aliexpress
25.03.2026
Need all drivers, not ISO, because aim install Windows 11PRO (not home editions). Standart driver for USB hub not work correctly, my audiocard not work :frowning: May be need other drivers? i do not know…
The drivers can be downloaded from the Chuwi website under Support > Support Center.
If there are no downloads available, you must contact customer service.
Drivers not download in support cetre. Need drivers
You can read the previous post; you have two options.
