While I was going through my Corebook’s installed software, I had removed the software called “ModeNotify”, aka the software responsible for changing between Performance Modes (by the use of "FN + Space), does anyone have this software installed and can send it to me?
Thank you
Edit: The install path is usually in C:/Windows/Program Files(x86)
See if contacting support@chuwi.com helps. You may have to follow-up a few times.
If the app is not designed as a standalone exe you would ideally need an installation package exe or msi file on Windows. Copying folder from C:\Program files might not work always.
I have tried but to no success, the restore points were returning errors and corrupting, i have recieved the ISO from Chuwi now and they suggested i reinstall but im gonna do a last attempt at going through the ISO for the installer
Corebook X i5 - 1245OH. I have ModeNotifyV 1.1.12 on my laptop. When I start my computer, a small black window appears and the message “not responding” appears. The Fn+space key does not respond. Other shortcuts work fine. What to do? Maybe re-upload the program?
Thank you for your reply. Repairing the app did not help. I still have a “ModeNotify not responding” popup. My laptop: XCorBXIZ17P24110215 Corebook X i5 - 12450H, program ModeNotifyV 1.1.12.
