I have Corebook x i5-1235u, 16ram.
Serial number: JCorBXIW4H231201669
Initially, Windows 11 was installed when I bought the device. I switched to Linux, but due to compatibility issues and drivers search, I decided to revert back.
I installed a new Windows 11, but it didn’t recognize the Wi-Fi module or the touchpad. I tried another installation, but faced the same issue.
I understand that I need a specific operating system. Please provide a source where I can download a suitable OS and drivers for this model. Also, I would appreciate instructions on how to install these drivers.
I was able to install the OS system. Now my main problem is wi-fi. The fact is that this device, which I indicated from above, very poorly catches communication with the wi-fi router.
I have a corebook x i3 10111u that has never had similar problems with wi-fi. Can you suggest or suggest how this could be fixed? After all, it was because of this error that I jumped from the Linux axis back to windows, I think that there are no adaptive drivers for the wi-fi module
