Does anybody know any good replacement charger for this laptop? The plug broke(i accidentally stepped on the wire and the plug got bent
Look for a charger with the same voltage, the same current (or more current), the same barrel diameter, and the same barrel polarity.
As an alternative you could also look for a usb c decoy cable with the same specifications and use a standard usb c charger that can supply the voltage and current required.
Cheers, Jaap
IF you send the model and exact serial number we may have a replacement
