CoreBox 5th I5-13500H Thermal Pad and Thermal Paste Specification
I own a CoreBox 5th I5-13500H and I am planning to replace the thermal pads and thermal paste of the cooling system.
I kindly request the original technical specifications of the thermal interface materials used in this model, specifically:
  • Exact dimensions (length and width) of each thermal pad
  • Required thickness of each pad
  • Thermal conductivity rating (W/mK)
  • Recommended material type (e.g., silicone-based, graphite, etc.)
  • Specifications of the thermal paste originally used or recommended (thermal conductivity, viscosity, or suggested model)
I would like to use materials equivalent to the original specifications to ensure proper thermal performance and device safety.
Thank you in advance for your assistance. I look forward to your reply.
Kind regards,
Francesco
This is a user forum. No one from Chuwi checks on us.
You should contact Chuwi support: service@chuwi.com
Thanks, Bruzan2025,
I have sent an email to support, but I’m also asking here in case someone has already replaced the thermal pads and thermal paste.
After 15 gg, and 2 emails to support one directly and one from the web, not received the reply. No good
