CWI 575 i5 camera driver not work
ZCoreBDW1H230100739
CWI 575 i5-1035G4 chuwi corebook 14/8/512gb Windows 11
I buy this product 12 february
On this week camera dont work in device manager usb descriptor error(43), i tryied install intel chipset driver, backup windows update, manual install many drivers for camera with intel arvstream, please give me drivers for this pc @Management please help!
Thank you for drivers. Im install all this software but camera doesnt work either
I tried to forcefully install different drivers on an unknown device like “intel r camera sensor”, I added it as an old device, I added all the drivers in the device manager, none of them were automatically applied to the camera. Has anyone encountered something similar on this model? Or does he know what exactly the camera driver is called? Because I physically opened the laptop and looked, the camera is visually fine and reacts to connecting the cable, and the problem appeared after a certain number of WIN 11 updates, but unfortunately there was no restore point with a working driver
Did it work before? what i send you the original windows that came with computer and you install it?
yes work before windows update, yes im install all in pack upper
check bios all physical ports enabled
install again windows and see if tat works
Windows installation tutorial: windows installation system tutorial
