Hello, I have this problem with my Chuwi Hi10 X.
I have already download the official driver but it won’t install. Is there something that can be done for this?
Try to use Intel® Driver & Support Assistant https://downloadcenter.intel.com/download/28425/Intel-Driver-Support-Assistant
Already tried it, but does nothing
Strange, this is definitely drivers from intel
. Try any driver pack program, like SDI.
Why do you need to reinstall the driver?Which part is the problem?The camera.Touch, bluetooth.Wi-fi.Gravity induction?You need to install the corresponding driver to make it useful.
The missing drivers are Intel® serial I/O host controller - 31AC and Intel® serial I/O I2C host controller - 31AE
No,no,no,I mean what part of your device has a problem that caused you to install the driver.
I reinstalled windows with windows 10 Pro 1909 and when finished some of the drivers where missing. I installed all of them, except this two that I cannot find.
Ok I see, then please copy this to service@chuwi.com.
Same problem here
After reinstall windows these devices has no driver
You should follow @Biosham advice
This will install a software which will read your hardware details and advice you the correct drivers
Except updating WiFi and bluetooth driver (which were already working) Intel® Driver & Support Assistant did almost nothing in my case.
@Deiab have you tried installing the driver that the Management have uploaded?
Hi, how are you?
I have the same problem too
When installing windows 10 pro 1909 I am missing drivers
and the camera doesn’t recognize them
I am also missing a thermal controller …
both devices use the same driver located at c:\Windows\System32\Drivers\iaLPSS2i_I2C.sys (version 30.100.1816.3)
you can try put them back in windows driverstore like stated here : (https://www.pconlife.com/viewfileinfo/ialpss2i-i2c-sys/ )
hai risolto? ho lo stesso problema tuo
Where can we find the Hi10x wifi drivers please?
