Hi everyone ,can somebody help me with my chuwi driver, i was able to install new windows 10 pro and install some off the driver except two device still unknown, try to search in this forum but the link is expired, maybe there is somebody who can help me with this driver?
Here is the official driver download
[Hi10 Pro] [Official Version] Chuwi Hi10 Pro Windows, Android, Bios, Driver, tutorial Download?
but there is a problem with it.
Its camera driver is for the wrong hardware and its touchscreen driver is for the wrong version.
My post #116 at [Hi10 Pro] [Official Version] Chuwi Hi10 Pro Windows, Android, Bios, Driver, tutorial Download contains download links to the correct
- Camera sensor unicam gc2355
- SileadTouch driver v17
drivers. There are a couple more explanatory comments in my posts #116 & further down page 6 of another thread - my driver links - page 6, post #116 - ChuwiForum
If you have any further problems I suggest you post in a more active forum [as well as or instead of here] such as www.tenforums.com
You will also find it worthwhile backing up drivers -
Backup and Restore Device Drivers - TenForumsTutorials
Best of luck,
Denis
The current thread is rejecting my factually-correct reply because it is too similar to my recent reply to the identical problem reported in another thread. This extra bit of text should allow the post to get through.
