Hi10 Pro Drivers
The problem of windows being erased on the hi10 pro occurred for the 4th time,
I consolidated all partitions and did a fresh install of MS Windows10 (version 22H2).
However, the touch does not work properly and there are two unknown devices.
(For other devices, driver installation is complete)
I hope someone can help me
The serial number of my hi10 pro is HQ64G42180303636.
kjh0411win,
It was my post that manonegra quoted above.
In addition to those download links, there are notes about other drivers in that post so I do suggest you click on the quote’s title to read the whole thing.
I hope those two downloads are all you need.
Best of luck,
Denis
Could not download file
It says route expired.
The file could not be downloaded.
A message like the one below is displayed
“Item does not exist or is unavailable”
I have no idea what is causing that.
The files are still there and their links have no expiration date.
We cannot attach files to Chuwi forum posts.
Go to this TenForums thread and download them from there.
My ditties - Chuwi Hi10 Pro drivers [post #2], other changes [post #3] - TenForums
And post any questions you have for me in that thread
[You’ll see a warning about it being an old thread but that does not matter.]
All the best,
Denis
friend
Thanks to you, I solved the touch problem
thank you
However, the camera sensor and G-sensor files are not accessible.
I have hi10-plus and hi10-pro
Why does hi10 pro only have problems under the same conditions?
Pro displays the Windows installation screen vertically starting with the cmos screen.
Do you know the cause of this problem?
I have just successfully downloaded all three drivers from that TenForums page.
I know nothing about Hi10Plus or any other Chuwi products.
The Bios determines the way the screen is displayed outside Windows. Only a Bios re-write could change that.
Denis
I downloaded and installed the two files through different paths.
problem solved thanks to you
Thank you so much
May luck always be with you…
