Drivers don't work propertly
I have just windows 10 on my Hi10 Pro
I’ve seen a lot of people asking for the same drivers and similar problems, but i couldn’t find any solution. I can’t find 2 of the drivers (i get a “missing driver” message on the devices mananager menu) I been able to find and install the touch screen driver, but is not working propertly and the calibration doesn’t work neither.
My serial number is hq64g42180101011
hi
try installing Chuwi drivers from a drivers installer pack you will find on several sites paying attention not to use virus hive trapping ones.
This program will set the missing drivers for you, even if they haven’t been signed by Microsoft.
In addition the other drivers will be updated too.
Dave
Here is the official driver download
[Hi10 Pro] [Official Version] Chuwi Hi10 Pro Windows, Android, Bios, Driver, tutorial Download?
My post #116 at [Hi10 Pro] [Official Version] Chuwi Hi10 Pro Windows, Android, Bios, Driver, tutorial Download contains download links to the correct
  • Camera sensor unicam gc2355
  • SileadTouch driver v17
    drivers because, at that time if not now, the official download had the wrong hardware list in it. There are a couple more explanatory comments in my posts #116 & further down page 6 of another thread - my driver links - page 6, post #116 - ChuwiForum
If you have any further problems I suggest you post in a more active forum [as well as or instead of here] such as www.tenforums.com
You will also find it worthwhile backing up drivers -
Backup and Restore Device Drivers - TenForumsTutorials
Best of luck,
Denis
I found that the Chuwi s/w dislikes my similar replies to similar questions so I have to add an unproductive extra bit of text before it would post my reply. So here goes again.
