My Chuwi needs full restoration (only windows 10 as Android 5 is uselles this times).
It’s CWI527 with serial: LQ64G42161201200.
Please provide Windows Installation process (scripts to restore the version with contains proper touch screen driver) and files - (windows with drivers to restore or just proper drivers and instruction how to use it).
if you also share the instruction I will be gr8full.
Step 2
The Tablet connects Hub and plug the USB drive and keyboard in the Hub as the picture shows:
Press power button. At the same time, please click the “F7” button continuously into the boot mode as the picture follows:
Step 3
The programming will last about 5 to 10 minutes. When it is finished, the tablet will shut off automatically. It lasts 5 minutes in the interface of Getting Ready and then it will restart Windows 10.
If you need to delete android follow this tutorial
