Where i find BIOS. BIN file for My Chuwi hi10 plus seri Cw1527 LQ64G42160809221?
Hello Ade, check here
http://www.mediafire.com/folder/3l1uito7pxhdxp1,lz5jskxmcqn8euw,izvch2f2wbvhiao,cyhacnx1v1cxjv3,5s3aoyzkirbtunq,bcvpe2zejfpmxxo/shared
thanks bro… but i can’t find a bios file. there are windows file only on folder.
can i install OS windows/android without bios on dead device? thx for your help before.
i have link bios from service@chuwi.com
http://www.mediafire.com/file/viexokn13i44fdo/bios%EF%BC%88Z8300%EF%BC%89.rar/file
this file for intel Z8300, i think this is suitable for my device with the same processor but after i flash to my chuwi via usb programer ch341a, my chuwi still not turn on. do you have solution?
hey dude did you fix it? I have same issue like you it seems like I am using the wrong bios file for mine, nothing works after using ch341a usb programmer… mine is Chuwi Hi10 Plus Z8350 (build number 20170905) LQ64G42170905836
Continue to reflect on your situation to service@chuwi.com.
thank bro so much <3
