FreeBook N100 Does not Boot
Serial number: ZFreeBCY4H240101314
Bought at Amazon USA nov-26-2024
The laptop started showing a Windows error, and restarting few minutes after login into windows. Right now is useless. I tried to reinstall windows but it shows different error messages just started the installer.
wow likely something wrong with your hardware if you cannot even reinstall windows. unfortunately the bios does not have memory check functions.
I’d suggest you to install Hiren’s Boot CD https://www.hirensbootcd.org/ on a usb stick and do some mem and ssd checks to see what’s wrong with your laptop, before you try to reinstall windows.
Memory test failed and then the device was frozen:
see if you can get a return in Amazon USa, if not you will need to send to repair
