¡ CHUWI GameBook finally released in Europe. A new gaming laptop for just 2300€!
AMD Ryzen 9 9955HX
GameBook is powered by AMD’s flagship Ryzen 9 9955HX processor - Zen 5 powerhouse with 16 cores/32 threads, 5.4GHz boost clock, 64MB L3 cache and 55W TDP for AAA gaming, intensive multitasking and professional content creation.
NVIDIA GeForce RTX 5070 Ti
With NVIDIA’s cutting-edge GeForce RTX 5070 Ti Laptop GPU , featuring 12GB GDDR7 VRAM, 140W TGP, full ray tracing, and 1406 AI TOPS in addition is powered by Blackwell RTX architecture with DLSS 4 and Multi Frame Generation to achieve ultra-smooth 191 FPS at 1440p and 149 FPS at 4K .
16-Inch 2.5K 300Hz Display
A stunning 16-inch 2.5K WQXGA (2560×1600) IPS display with 300Hz refresh rate, 100% sRGB gamut, 500-nit brightness and 16:10 aspect ratio
Memory and Storage
The GameBook packs powerful 32GB DDR5-5600MHz RAM (expandable to 64GB) and a 1TB PCIe 4.0 NVMe SSD, plus dual M.2 2280 slots (one PCIe 5.0-ready)
Thermal Management
Advanced cooling system with dual fans and three heat pipes, complemented by a 77.77Wh battery with 140W USB-C PD fast charging and a 250W power adapter for uninterrupted gaming and productivity.
RGB lighting and numeric Pad
The GameBook features a full-size keyboard ,paired with a spacious touchpad and 2MP IR camera featuring physical privacy shutter for secure video conferencing.
Availability
Soon you will be able to check the reviews on Youtube, and if you do not want to wait, and wish to feel it on your hands as soon as possible you can get it on the CHUWI stores:
You can also get discounts during our sales promotion every month, so for sure it will be cheaper
SPain
Germany
