Laptop was delivered today. I bought it from minikpc.com There is a slight backlight issue ansd some crackling noise when i move the lid. Should i send it for replacement?
It is only visible with black background.
JGeBPLIC1H250400239
JGeBPLIC1H250400239
When you buy a device and it doesn’t work as it should the first time you use it, there’s only one solution: return it.
Return it
