Gemibook Pro 14" N5100 RAM upgrade?
Hi, I wanted to know exactly if my laptop Chuwi Gemibook Pro 14" 2K Celeron N5100 can get a RAM upgrade or if I can replace the RAM already Installed to have more.
Serial Number:
I bought it on MercadoLibre. I bought it on January of 2023.
Hello, now we are on holidays, but i checked the book of specifications we have and it says this of that model.
There are 2Pcs, 2280, maximum support 1T
1Pcs built-in (SATA3/PCIE hardware 2 choose 1)
+1 Pcs extension (SATA3)
So in theory you can upgradeup to 1T
Yeah, thanks, I bought a SSD from MercadoLibre and I thought it’ll work, but it didn’t and I found that the reason was that it was a NVMe SSD and my laptop does not support that kind of interface, the interface that does work is SATA and I didn’t know that. Thanks for the help.
