Meu GEMIBOOK PRO / CWI529 (GeBookPQ256G21024836) não liga, não acende as luzes de carregamento, porém esquenta o carregador e a placa mãe. Solicito DataSheet da placa-mãe para verificar componentes.
My GEMIBOOK PRO / CWI529 (GeBookPQ256G21024836) does not turn on, the charging lights do not turn on, but the charger and motherboard heats up. I request the motherboard DataSheet to check components.
So you need like the diagram to check components? Do you know how to repair? and that is why?
I’m an electronics student, and with the datasheet I’m going to try to discover the component that is preventing the Gemibook Pro from turning on normally.
If it is possible, my model is the CWI529.
Can you send me a sample of a datasheet so i can ask more easy to tech?
