I have accidentally got my SD card stuck in the sd card reader, how do i get it out?
Can you show us a picture of it?
its gone inside of it
Is the memory card in the slot or did it go in below/above it?
If the memory card is in the slot and does not come out, then the connector is probably broken, you can try to drip super glue onto a toothpick and try to stick it to the memory card, and then pull it out
(but I would recommend disassembling the laptop, it is much safer).
If the memory card is not in the slot, then most likely the only way is to remove the bottom cover of the laptop.
it went under the port and i got it out!
