Stuck Micro Sd Card
My micro SD card is stuck in the slot and when I try to push it to get it to eject it just pushes farther and farther into the slot and now I don’t even see the card. Any suggestions on how to get it out?
Hello
The card must have slipped from the slot, or slot had broken. Your device is a laptop or tablet?
it is a HeroBox Mini PC
I would recommend to open the Herobox and check if sd slot has been broken (worst scenario) or Micro SD Card had slipped out of the slot.
Following video may help you to open and check:
Starting in 3min3sec you have disassembly sequence.
Chuwi Herobox Gemini Lake MiniPC - unboxing, testing and teardown - YouTube
Regards
