Hi!
I bricked my HI 10 PRO and need the bios. My serial # is HQ64G42170100072. Help me, please
You can check them here
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
If that does not work. Reinstall the system again.With these files
@manonegra222
The bios is correct for your device. If the tablet turns on, booting with the bios pendrive inserted, the update will be carried out automatically.
If it doesn’t start, you will need a clamp to record the bios
