I would like ask some one to teach me how to increase system resources while Im using Hi10 Air.
My resources are usually less than 20MB sometime 2MB.
Please give a hint to increase the system resouces.
Thanks.
Thanks.
If you mean that you have all the storage occupied, possibly by Windows updates, the system is cleaned only in about 20 days after being updated. If everything is fine and you want to move the process forward, you can go to “this PC” and right-click, properties, free up space. A scan will start and when you finish you must click on a System Files button to start a scan of the Windows installation files again. When finished, the window will show the files of Windows updates that you can delete to free up space.
Thanks.
But i mean is system resource.
As much as I can uninstalled unnecessary software, but still lacking system resources.
