Hi10 Xpro Android 13 downgrade
Hi my Hi10 Xpro has Android 14, but the soft I use work on Android 13 and under. Soi is it possible to downgrade the tablet?
As far as I know:
You need a rollback package.
You need the zip file to install it, erasing all data.
Where can I get this rollback package?
What software doesn’t work on Android 14 ?
Hi
Launch x431 doesn’t work with android higher then 13
please indicate your serial number of your hi10xpro
JH10XpAB60240801716
okay i’ll request a firmware right away if there is an android 13 for your hi10 xpro
We dont have 13 for yours. But if you want i send you one and you try to install
if it does not work then you reinstall yours
PRevious versions:
Your now version:
How to:
Hi10 XPro: https://drive.google.com/file/d/1yobv-dCQHQjKHTp=drive_link
Thank you. I’ll give a try.
