Hi10 xpro WARNING: NO VALID OS FOUND! (Help)
please help me fix this when i boot up my tablet it says “WARNING: NO VALID OS FOUND!!!”
i tried to flash all available firmware but still not working
Here’s my S/N YH10XpAB30231107793
This is for your Tablet
OS
How to:
I showed this to Tech. They told me you need to try to install again, and if that does not work it means is a hardware problem. In that case it needs to be sent to repair.
In which shop did you buy? and when? (to see if its under warranty)
I hope you can solve it¡
Is there a possibility that the bootloader is lock and why still there’s No valid OS found after flashing?
Tech told me , that they dont think that is the issue, they think is more related to hardware
