Hi10pro android have 13gb
Hello!
I got the android system .zip from chuwi everything works great git single boot but why my data only has 13gb for my data the rest is free how to fix it? Similar in gpt.bin but I don’t know what to do with it.
Oryginal v1 Dostałem system android .zip wszysko dziala super git sigle boot ale dlaczeho moje dane mają tylko 13gb na moje dane reszta jest wolna jak to naprawić? Podobbo w gpt.bin ale nie wiem co z tym zrobić.
Tanks
@manonegra222
Hi10 pro is a tablet that combines two original operating systems: Android and Windows. This was possible because both Google and Microsoft developed drivers for the Intel Z8350 processor that it was equipped with. The combination of both systems requires separate storage for system and user files, so the unit has two partitions. One for Android, of the size indicated and another for Windows of an approximate size of 49 GB. In the case that you only want one of the systems or you have deleted the unwanted system partition, it is possible to give the free storage to the other system. In the case of Windows, by extending the C drive where the system is installed and, in the case of Android, by performing a new installation replacing one of the original files with another that gives a larger size.
https://1drv.ms/b/s!AqpKvT8-VB_8-R4v6MOtNz3yaqJl
https://1drv.ms/u/s!AqpKvT8-VB_8-SELPfuN22nnadCl
I have thos rom but i bricked it (i wait for repaired partitions)
Yes, with the installation of the two rooms the partition map is recovered. You must first install Android
Bro, i install this and work very good but the problem is android_data (partition or Partition) i use mod erwcovery in intel please check file tied for android_data
https://www.mediafire.com/file/wayshpo83nmkphu/ChuWi_Hi10_Pro_dual_system_flash_tutorial.docx/file
