frtmr
March 6, 2020, 8:50pm
1
Hi from Turkey.
To have Windows and android.
The android part of my HiBook Dual boot tablet does not open.
I am the owner of Model: CWI514
HiB Q64G45160401881
I am trying to return to factory settings but I could not (Power with Volume + 5 seconds)
Please help me.
Try pressing the power and volume button - for one second, releasing the power button and pressing the volume button -
frtmr
March 7, 2020, 9:42am
3
Thank you.
I was able to enter the way you said but android does not start after factory reset.
It does not exceed the screen with the text intel inside.
frtmr
March 10, 2020, 9:08am
4
Hi again.
Can you help with reinstallation with usb ?
When installing Android, you will lose Windows and you will have to reinstall it unless, in the Android installation files, there is a “non-erase-all” flash file that you would have to use for the reinstallation of Android without losing Windows.
Tutorial:
The instruction to Reinstall Windows 10 for Chuwi HiBook:
http://www.mediafire.com/file/97389nnmd3xz51m/HIBOOK.mp4/file
The Instruction to Flash Android on HiBook (Win10 Remained):
http://www.mediafire.com/file/fa44mj4vw0lgi9t/ChuWi_Hibook__dual_system_flash_tutorial.docx/file
And this is the tool of android:
Password:
Android:
Chuwi HiBook Android download:
https://chuwiinnovationtechnolog … cd3i03s7948h7cffwtm
When you install Android for HiBook using this file, Windows OS will be cleared. After installing android, please install windows 10 again.
Chuwi HiBook Android ( without losting Windows , using usb flash disk to flash ):
https://chuwiinnovationtechnolog … w4ibp7fn49zewsw0kh9
When you install Android for HiBook using this file, Windows OS will not lost.
Windows:
Chuwi HiBook Windows download:
http://www.mediafire.com/file/9eclv2noksk31mk/Hi_book%E6%AC%A7%E8%A7%84%E8%BD%AF%E4%BB%B6.rar/file
sengst
June 5, 2020, 10:49pm
6
Android download links are down or pointing to the wrong location (Android tool). Could you please update the download links.
Ramiz
April 6, 2022, 10:23pm
7
can i get just the drivers?
the windows drivers, plz
