ok guys - i am lost here - how do you update the android rom? i have th edriver installed - but can not find flash in ddownloaded rar file.
songchen888 if you need to update the Chuwi Hipad Plus check the Android 11 upgrade steps here: Flash instruction for Chuwi Hipad Plus update to Android 11
Regarding the .rar file you have to unrar it before and then I suggest you to rename the file folder name with a shorter name.
