More of a question really. Have had my corebook pro for 5 months now and I am very happy with it, however, nowhere can I find out how to take a screenshot with it. Wondered if anyone else had the same problem and or solution. Thanks for a great product ![]()
Hello paulm
On top of F12 key you should have the PrintScreen feature. (PrtSc). If your keyboard is configured to use the F keys as standard, to use the screenshot you should press Fn+F12.
But… a better way, so you can select the parts you want to screenshot, is to use Snipping tool.
You should be able to find it when clicking on Windows button and typing “Snippin…”
Regards
