When you go to support → Downloads and enter the serial number, you get an OS download option but its a zip file.
If i try to boot a normal WIn11 ISO, it says it can’t find any disks and its incompatible. I tried installing the drivers from the Driver download but it didnt help.
Please give me a ISO i can boot and install on the Hi 10 Max, Linux isn’t working well enough for me so I want to go back to windows.
What Linux distribution did you use? What didn’t you like? Did you try FC 41 KDE mobile, it has the Plasma mobile interface meant for phones and tablets.
Personally I neither like Windows nor Linux on tablets. I prefer another system.
On my minibook I could install Windows with a drive flashed by Windows Media Creator. BUT, I needed to connect a USB keyboard, mouse, and Ethernet adapter to compensate missing drivers. After installation I applied the Chuwi drivers and it worked.
I created an ISO with nLite where all drivers are already implemented. If you are interested and allowed here I can make it available for download in Google Drive
You contributed nothing to resolving this situation. Jaap just went on rambling about what distros he likes and how all his ISOs worked on a completely different device. Don2 told me to get the appropriate drivers using the serial number - which I said in my original post that I did.
You two are clearly the problems in front of the PCs.
The thing is, we at least tried to help, if you call every helping hand that doesn’t get you to your goal straight away a bunch of nuisances, then I don’t really know what to think of that.
Please do not argue, i think every user in this forum always try to help on its own way and for us we appreciate a lot because sometimes due to the amount of work we cannot offer all the help we would want. So every little help is welcome. We never know where will the problem be found
Устанавливайте 11 24H с Скачать Windows 11, затем скачайте обновления и в обновлениях разрешите установку необязательных драйверов в настройках сместите панель влево, получится как в 10-й версии, всё будет не по центру, а как все привыкли. Здесь driverpack.io согласитесь на установку, затем в режиме эксперта отключите то, что не хотите устанавливать
