LarkBox X 2023 nvme compatibility
Hello all,
Do you someone know what kind of M.2 NVMe this mini PC supports?
Mini LarkBox X 2023 comes with 512 SSD Sata NGFF NVMe, but I`d like to install M.2 2280 NVMe with more read/write speed.
Does it support Gen4 NVMe?
Does anyone know if it supports m.2 2280?
Thank you all,
Then, just support M.2 Sata 2280 NGFF is that correct?
Yes, that’s correct, that SD will be recognized.
Your statement is false, and it’s as easy to prove as installing one NMVe drive and seeing that it works.
