Linux Mint 21.1 - get sound on Linux on Larkbox
new tuto, simpler and faster.
First, I installed Linux Mint 21.1 Cinnamon.
then I created a script “blablabla.sh”:
script start
#sound enabler for linux mint 21.1 with essx8336 in Larkbox
#latest kernel version as of 20230321: 6.2.7
#first, OS update and sof install
sudo apt update -y && sudo apt upgrade -y
sudo apt install firmware-sof-signed
#second, install latest available kernel ()
cd /tmp
wget https://raw.githubusercontent.com/pimlie/ubuntu-mainline-kernel.sh/master/ubuntu-mainline-kernel.sh
chmod +x ubuntu-mainline-kernel.sh
sudo mv ubuntu-mainline-kernel.sh /usr/local/bin/
#check available latest kernel version
ubuntu-mainline-kernel.sh -c
#install latest kernel version
sudo ubuntu-mainline-kernel.sh -i
#list installed kernel
sudo ubuntu-mainline-kernel.sh -l
#third, forcing grub to load specific driver: add snd_intel_dspcfg.dsp_driver=1 to GRUB_CMDLINE_LINUX_DEFAULT
sudo tee /etc/default/grub >/dev/null <<'EOF'
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash snd_intel_dspcfg.dsp_driver=1"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
EOF
sudo update-grub
reboot
script end
enjoy!
Actually, with Linux Mint Cinnamon 21.1 and kernel 5.15, only grub editing is required ( /etc/default/grub ), modify GRUB_CMDLINE_LINUX_DEFAULT to add snd_intel_dspcfg.dsp_driver=1 then run sudo update-grub:
In short:
sudo sed -i "s/quiet splash/quiet splash snd_intel_dspcfg.dsp_driver=1/" /etc/default/grub
sudo update-grub
sudo  reboot
Modifying iso ( /boot/grub/grub.cfg ) by adding snd_intel_dspcfg.dsp_driver=1 between “splash” and “–”, you have sound in live mint:
menuentry "Start Linux Mint 21.1 Cinnamon 64-bit" --class linuxmint {
	set gfxpayload=keep
	linux	/casper/vmlinuz  file=/cdrom/preseed/linuxmint.seed boot=casper iso-scan/filename=${iso_path} quiet splash snd_intel_dspcfg.dsp_driver=1 --
	initrd	/casper/initrd.lz
