MiniBook X 2in1 N100 how do i create the usb to restore OS?
Hi serial number ZMinBXHY4H240202000
Hi bought my Chuwi Minibook X 2in1 with CPU N100 and 12GB LPDDR5 from Aliexpress, about a week ago.
Want to install Window 11 Pro using nomral way, have license and want to have the pro version installed (created a usb using microsoft tool).
Want to have plan B as i saw some people had some little issues.
And have several questions, because I want reinstall the OS.
  1. Where can i get the restore OS for my serial number and drivers?
  2. Saw on diferent posts restore images but they are .zip, tried copy paste just to test if i can make the usb but wont copy the file that has 8GB, usb if fat32. How do I make the USB and boot from it?
    3. How do I install the drivers as I dont see any .exe file?
Thanks anticipated,
WIndows:
Drivers:
How to:
Windows installation tutorial: windows installation system tutorial
If you have any problem installing, you can come back here.
One last question if I reinstall windows using original Microsoft img. Windows 11 Pro 23H2 will it still functions as it was from box?
And can i have the lates bios update?
I dont think it will work properly as all our Windows are Home, not Pro, so its possible some drivers and things may not work.You could try and see, If not you can always go back to the old Windows with the files i sent you.
The latest Bios is the one you have. We did not develop a new one for your serial number.
Hello ! same question here.
How do i create a usb key to restore OS ?
ZMinBXHY2H230200972
Windows Tutorial: windows installation system tutorial
