Minibook x N100 "no audio device is installed" (solved)
My minibook x (n100 version) has no sound after re-installing windows os.
I installed the os from CHUWI. Now I have “no audio device is installed” for my audio devices.
I have searched and did everything I can find on this form with no success.
Does anyone have the driver or solution for this ?
Thank you!
By providing your serial number you can download a Windows 11 AND a driver package here:
Support Center - CHUWI
Maybe you forgot the driver package?
is better he write it here , @godzebu79 can you provide me the serial number ?,
I was able to download the proper driver from the net. The sound is working now.
Would you mind sharing the file you downloaded so other users will find the help when they read this topic?
Which Serial number is yours? So i can edit my message and write the batch of Serial numbers yours belong to.
serial # is ZMinBXHY4H230900406
I got the file from here
https://dl.driverpack.io/driverpacks/repack/Sounds_Realtek_DCH/Realtek/FORCED/10x64/9618_UAD/Realtek-FORCED-10x64-9618_UAD-drp.zip
For people who bought the batch of computer of Serial Numbers between ZMinBXHY4H230900001-ZMinBXHY4H230901500 .
Could you please provide the driver pack of windows 11 for ZminBXHY4H231002582? I’d like to have it stored for my further re-installation.
Drivers for Batch ZminBXHY4H231002 to ZMinBXHY4H231003500
thats interesting. difference serial no have difference driver…
My SN in this range.
If someone else in this range doesn’t have Intel High Definition Audio driver - here is drivers list for you that does NOT included in “MiniBook X N100 Drivers.zip” (why, Chuwi?), but help me to fix “muted” notebook.
Intel(R) Smart Sound Technology (Intel(R) SST)
intcusb.inf_amd64_cdadcbaa7b661890
intcoed.inf_amd64_fa98a0d039ca4663
intcaudiobus.inf_amd64_d4b4926bdb629e78
Realtek High Definition Audio Driver
hdxsstip3.inf_amd64_a9e20b32cdc431eb
hdxsst.inf_amd64_3c12c70c1a9d7f28
Pack: 203.7 MB file on MEGA
P.S. “How can I check drivers by myself?” - What I have do:
  1. Install clean Win11PE (from Chuwi download center by S/N)
  2. Install Chuwi drivers from zip by "device manager > driver add (there is option for recursive folder install)
  3. DriverPack Solution (be care with it, cuz it very very bad software if you push wrong button) check drivers that need for sound/audio (gui has toggle for detailed info about drivers+versions)
P.S.2
for export drivers:
dism /online /export-driver /destination:C:\Drivers
Thanks, I had the same problem, resolved !
The Minibook X has the Realtek ALC269 chipset so the best place to get the drivers is from Realtek. Their package will uninstall any old or wrong drivers automatically before it installs the new one. I noticed the audio sounds better somehow! MiniBook X N100 audio drivers (Realtek ALC898,ALC269)
Not able to get sound with the following SN:
ZZMinBXHY4H240702319
I’m downloading the realtek driver above to see if it works.
Edit - I downloaded the latest from the Download center and my audio turned on immediately.
