Minibook X n100 with stylus pen
I am planning to buy the Minibook X.
Since note-taking is one of my main uses,
I am also considering which pen to use with it.
Are there any touch pens or stylus pens currently supported?
Which product do you recommend the most?
MiniBook X does not have MPP protocol, so that means is not compatible with stylus that use this function. Currently the only pen compatible is H8. Is capacitive style, same as the touch of the finger. So any pen who is like a touch pen will be able to use. Depends on how much you will use it.
If for you taking notes and using the Pen is super important. Maybe you can wait for a new tablet we will launch in July, you can use stylus Pen with MPP, is windows and more or less same features as MiniBook X, it has a magnetic keyboard. H7 pen is compatible and will be better . Price will be similar or cheaper.
I still want to buy the Minibook X.
Could you please tell me if the H8 works well on the Minibook X?
I don’t need advanced features like pressure sensitivity for line thickness variation.
I’m just concerned about palm rejection and jittering.
I have tried the H8 in Minibook X several times and is ok, for normal use, not for drawing or using special programs.
If you really want the Minibook X, you can always buy it. And then if the Pen H8 does not really suit you, you can send back. it always depend on each person taste.
So, in general, should I not worry about palm rejection and jittering?
No, not much, in which app will you write your notes?
I think… i will use OneNote or Drawboard PDF
Can you check it…?
I installed Onenote in MiniBook X and in theory it works ok.
