Recently i installed original windows 11 pro to my Chuwi Gemibook Plus After i installed it my speaker and the touchpad of the laptop are not working so how can i solve this please respond me🥲
Serial Number : LGeBPLIY4H230903719
you can try this
Can you guide me to install above driver package to my laptop
try this, is quite simple, but is not the same name file you just look for the speaker and Touchpad
Actually i have follow the above tutorial but it’s not gonna work dear if you can plz at least give me an orginal chuwi windows as bootable software with all of the drivers for gemibook plus plz😭
I send you the drivers of WIn 11, we dont have WIn Pro
Все драйвера ставятся Driver Search - DriverPack в режиме эксперта соглашаемся потом отключаем все лишние галочки если первый раз звук не стал повторяем и все встанет один драйвер грузится при загрузке с центра обновлений только поставте галочку в необязательных разрешить
Oh dear i also installed the VC3 drivers but it’s not gonna work please help me dear if you can please send me the original iso image of windows that customized by chuwi for gemibook plus.Then i don’t want to install drivers anymore because official windows that customized for chuwi gemibook plus have all the drives in it plz plz help me:pray:![]()
Thank For Your help after months my laptop strated work properly now once again thank for your help i’ll appreciate you:raised_hands:t2:
