Hello can you please share bios dump from model above my s/n: SCoBAPYZ2H260100659
What problem are you having with the laptop ?
it doesnt start at all nothing happens when i try to use turn on button(all current voltages on board are presented: 5v 3.3v even on bios flash). power adapter is okay i check it and try spare one…
all that happend after Windows update was applied
Let’s take it one step at a time.
Do you mean that you can’t access the BIOS ?
Have you checked the voltages with a multimeter ?
If it happened after an update, it could be a software or hardware issue.
Do you know about computers and/or electronics ?
